View stat rate limit statistics to view the total dropped packets and bytes.
- In the Device Physical View, select a port.
- Select Port.
- Select the Stat Rate Limit tab.
- Select one or more values.
- Select the type of graph to create.
Stat Rate Limit Field Descriptions
Use the data in the following table to use the Stat Rate Limit tab.
Name |
Description |
DropPktRate |
Indicates the drop packet rate. |
DropByteRate |
Indicates the drop byte rate. |
DropTotalBytes |
Indicates the total bytes dropped. |
DropTotalPkts |
Indicates the total packets dropped. |
